Need Help with 4L60e transmission install
Old Jan 8, 2006 | 12:13 PM
  #51
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Originally posted by 82knightrider
Can you still get it rebuit for free at aamco
Since I had missed the inspection month, the warrenty is no good. I was trying to find a buyer for it a few months ago, but they were no takers. If I was aware of the problems before it was removed I could have had rebuild. But I was not made aware of it until after they had the new transmission put in.
My orginal plan was to find a buyer, then take the car to AAMCO and have it check out. If there was any problems with it, then it would have been rebuild. So somebody could have had a new 200c pretty cheap. But there was no takers, so its water under the bridge.
I would also like to note, that the AAMCO lifetime warrenty requires that the transmission is check by AAMCO every year in the aniversery rebuild mouth. Since I didn't find a buyer back in Setember, I missed the checkup requirement back in Oct. because I had already decided to replace it. So when the new 4L60e went in last week, the lifetime warrenty on the 200c was dead!
Old Jan 22, 2006 | 08:29 AM
  #52
BruceEmbry's Avatar
Final Shift Table
Picture below is the final shift table for the my Firebird.
Attached Thumbnails Need Help with 4L60e transmission install-finalshifttable.jpg
Old Jan 22, 2006 | 08:40 AM
  #53
BruceEmbry's Avatar
Part Lists
Required Parts to convert from 200c to 4L60e Transmission
Item
Part Number
Description
Source
4L60e Transmission
GM Performance Parts
TCI-377000
TCI TCU Controller
Summit
RPC-250-1223
Electronic Cruise Control Kit
Summit
CABLE-X Speedometer drive unit
Bowtie Overdrive Best price.
9802-Auto
Tailshaft Housing, 98-02 Camaro/Firebird, w/Automatic
Trans Am Creations USA (305) 769-0985
Torque Arm
From any Fbody with 700r4
Hawks Thirdgen
Alu Drive Shaft
Hawks Thirdgen
LS14L60EXMB
LSX Swap – 4L60e Trans Cross-member
Spohn
Trans Inspection Cover
GM Parts
Torque Arm Bracket outer
GM Parts
Torque Arm Bracket inner
GM Parts
Exhaust Hanger Bracket
GM Parts
L-Shape Exhaust Hanger
GM Parts
Transmission Cooling Line
GM Parts
GM Parts
16
Other Transmission Cooling Line parts
Reference V6 on 2002 F-body.
17
Slip Yoke
GM Parts
18
Universals
GM Parts
19
Dip Stick
GM Parts
20
Various Hardware bolts, nuts as required.
Various Sorces
21
Shifter Modification
700r4 shifter from ~1990 Camaro
Remove detent bracket and install on original auto shifter.
22
Modification of TCI TCU harness
Wire, 2 relays etc needed for modification of control harness
To mount TCU onto the ECM, the TCU harness must be extended 20 inches.
23
Small Starter
Required to prevent modification to transmission and inspection cover
Autozone
Shifter conversion, please see above notes about shifter. There is no need to purchase new cables, brackets etc. All you need is a 700r4 shifter out of a Camaro, a Dremal tool, drill, and drill bits.
Performance, very fast up and down shifts. Chirping wheels going from first to second and second to third.
Final electroinc system interface diagram
Attached Thumbnails Need Help with 4L60e transmission install-electronic-system-interconnects.jpg
Old Jan 22, 2006 | 11:55 AM
  #54
82knightrider's Avatar
Transmission: TH200C....700R4
thanks bruce
Old Jan 28, 2006 | 04:18 PM
  #55
BruceEmbry's Avatar
Hi All,
Some pictures of the car.
Attached Thumbnails Need Help with 4L60e transmission install-ext-driver-side-web.jpg
Old Jan 28, 2006 | 04:19 PM
  #56
BruceEmbry's Avatar
Another
Attached Thumbnails Need Help with 4L60e transmission install-rightside-int-web.jpg
Old Jan 28, 2006 | 04:21 PM
  #57
BruceEmbry's Avatar
One More
Attached Thumbnails Need Help with 4L60e transmission install-corner-web.jpg
Old Jan 28, 2006 | 04:24 PM
  #58
BruceEmbry's Avatar
Last
  #59
very clean man.Two thumbs up for you
Old Jan 28, 2006 | 04:47 PM
  #60
BruceEmbry's Avatar
Thanks!
Old Feb 11, 2006 | 05:04 PM
  #61
brutalform's Avatar
WOW! Talk about INFORMATION... Great Thread!
Old Feb 17, 2006 | 10:51 PM
  #62
BruceEmbry's Avatar
I see a lot of people doing the shifter change out instead of converting the shifter like I did. Maybe this thread should have it name change and made into an sticky.
Old Feb 18, 2006 | 04:39 AM
  #63
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Bruce,
I changed the entire set-up on my son's Camaro. If the previous owner hadn't trashed the assembly and the Steering Lock Cable in our vehicle your method would have been a much better choice. Finding an early third gen shifter assembly in good condition was a problem for us. The complete changeover to the newer style isn't a big job but it's definately a more work than your modification.
Another viable alternative is the B&M MegaShifter console mount(depending upon what the owner is after) that might be the best choice for some. If we weren't after a "STOCK" look we would have selected the MegaShifter.
Sincerely,
Kurt
Old Oct 19, 2006 | 09:12 PM
  #64
BruceEmbry's Avatar
HI all,
I know this thread is almost a year old. But I thought an update was in order so the rest of you can see what I did. The end of the story is, the car has preform this past year with absolutly no transmission problems. The high output alternator went bad over the summer and had to be replace. I have put about 5000 miles on the car this past year.
Gas mileage on the highway has stayed around 27MPG. This really help a lot when the gas prices were up the past summer.
I have recently changed the insurancce company to Hagerty, full coverage with a declared value of $15,000. Must less then what I was paying USAA.
Old Dec 28, 2007 | 01:28 PM
  #65
BruceEmbry's Avatar
Re: Need Help with 4L60e transmission install
Hi
Happy New Year 2008,
Well its been 2 years since I did the converstion and all is well. I put on about 7,000 miles this past year. Car has remained trouble free.
Old Feb 22, 2010 | 07:48 PM
  #66
BruceEmbry's Avatar
Update Feb 2010
Hi All,
Its been a few years since I created the post.
All is well, the Firebird still lives. It has a new home in Wilson NC.
I have not had any proglems with the transmission install except for one.
When cruising down the highway, the speedometer would bounce and cause the Electronic curise control to loose lock. So I have added in a Dakota Digita. SG-5 to the mix. The SG-5 has solve the problem with the curise control. Please see attached image for details on the wiring.
Attached Thumbnails Need Help with 4L60e transmission install-drivetrand-firebird.jpg
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
formula_novice
Aug 18, 2015 08:48 PM
