T-56 grear sizes????
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am getting a T-56 from a 94 Firebird. Does anyone know the gear ratios??? Thx guys.
Engine: LS3
true.... i was being lazy. i became un-lazy 5 minutes ago and found what i was lookin for. haha
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
well now you can be pro-active and post it up.
otherwise some guy will be doing a search, open this thread, and just waste his time.
Engine: LS3
geez ok ok, don't have to be so snappy about it......
94 T-56 ratios type:MN6 ID:GU6
rated at 400 ft lbs.
1st:2.66
2nd:1.78
3rd:1.30
4th:1.00
5th:0.74
6th:0.50
R:3.42
1st:2.66
2nd:1.78
3rd:1.30
4th:1.00
5th:0.74
6th:0.50
R:3.42
Whats the point of a 3.42 with a 4th gear 1:1 ratio on a 6speed. I could see it with a 5th gear 1:1 but not a 4th. You are rendering your 6th gear useless.
Heck, with 4.10's you would be doing 75mph in 6th gear @ 2000 rpms with that T56 gear ratio. The only time you could use 6th gear is if you are running the SilverState Classic with a 400+ hp motor and a suspension setup safe enough for 160+ mph because even then you are not going to be pushing through the air more than 3500rpms in top gear for over any 30 sec maximum interval
Engine: LS3
Well I am putting this tranny in a 500HP 383. That is gonna be my daily driver for 3 seasons a year. And I am gonna use it a lot on the highway. The 6th gear is really gonna help with gas, esspecially with the 4.10's in the 12 bolt.
But that is just me. In a stock 94 TA, it does seem a tad stange, but not realy. IMHO.
Pac J
May 17, 2020 10:44 AM
