Rear end gearing help
Old Sep 13, 2005 | 07:52 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
I have a stock firebird with a 305 tbi and its a one legger what gears do i have in it right now? and if i put in a 3.42 posi rear what kind of difference, would it be noticeable?
thanks
Old Sep 13, 2005 | 08:12 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Stock was a 2:73 10-bolt. So do some reasearch for replacement parts.
A 3:42 is 3-series ratio and you will need the same Limited slip carrier.
Your biggest concern would be the spline count on your axle shafts,they could be 26 or 28. 89 was the changeover to the 28 splines. Not a simple job changing gears, its up to you to decide if its worth it.
Old Sep 13, 2005 | 08:31 PM
Engine: LO3
no im not replacing the gears im looking into buying a whole rear end with the 3.42 gears already installed. Whats the difference between the 26 and 18 spline? and would i feel a difference?how much?
thanks again
Old Sep 13, 2005 | 09:14 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
You won't have to worry about axle splines if you are replacing the whole rear end, b/c they will already be the right ones. If you are going from a 2.73 to a 3.42 you will feel a big difference in acceleration, especially with a posi. It's probably one of the most noticable mods you can do.
Old Sep 14, 2005 | 05:01 AM
ede's Avatar
ede
how in the hell would anyone know what you have in it now if you don't? why don't you get under the car and look.
Old Sep 14, 2005 | 09:50 PM
Engine: LO3
how about theres no reason to be an a$$hole and i have been under my car sorry i dont check whick rear i have. Thanx for the responses other than the last one and is it a huge difference in acceleration? cause i just got a ticket and cant afford to get another
Old Sep 15, 2005 | 04:46 AM
ede's Avatar
ede
how about there's no reason to be lazy or stupid but it didn't stop you did it
Old Sep 15, 2005 | 05:13 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
as far as stock. it may not be the one mentioned. it depends on what options there were for it.. I now my berlinetta can with the 3.08 rear stock.. but it also had options for the lower (numerically) ones as well
Old Sep 16, 2005 | 10:04 PM
Engine: LO3
thankyou angelis and for all the rest of you i dont have time to do it sorry. With all the school and work i hardly have time until winter. I havent even had the car a year now
Old Oct 16, 2005 | 02:07 PM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
you could have 2.72, 3.08, 3.23, or 3.42 gears, best way to check is punch in the rpo codes to find out which you have... (without having to tear open the rear)
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
