Trans filter Q. need some quick info...
Car: 84' berlinetta camaro, digital dash n' all.
Engine: carbed 305
Transmission: 700r
Hi all,
I have my trans pan and filter out (700r4) and started to put the new filter in and it just falls out, it will sit for a second and falls, it is verry loose.
I checked for the O ring in the pickup tube hole and the old filter and its a no show....so that cant be stopping it. Unless the trans ate it at some point...
The new filter I bought (4 months ago) is correct for the trans this I know..
It has a ribbed orange rubber O ring on it (the new one) but dont seet securely. It came from either Advanced Auto or Autozone.
Has anybody had any experience with this?
If so did it seat tight or stay loose?
Will the pan hold it in place and secure If I put it in?
Its 230 now and I need to pick up the wife at 5 so any replies soon would be greatly appreciated. Sorry I cant put pix up my computer is ancient...
Car: check
Engine: check
Transmission: check
As long as the old seal isn't in the pump body, you need to seat the new filter with a bit of force. They almost snap into place. Use some lube on the new seal and push up (don't hit it) on the filter directly below the tube.
First time I did one on a 700R4 I thought I was going to break the filter.
RBob.
RBob.
Car: '89 Firebird Formula
Engine: 305 TBI
when i took the old one out the oring got stuck inside, didnt relize at first, it was a pain in the *** to get out of there too..
i think i used some snap ring pliers to help me get it out or something
Engine: carbed 305
Transmission: 700r
Thank you soo very much,,, I thought I was gonna have to make the 3 mile walk to the parts store....
My berly has 101,xxx miles and had what looked to be the original filter in it....and the fluid was auburn and almost looked brown...*shudder*...time for round 2...
Again, Thank you....
