tranny fluid
Old Sep 15, 2005 | 01:11 AM
s0n's Avatar
s0n
Car: 87 GTA,85 305
Engine: 350 tpi,305 carb
tranny fluid
ok i bought an 85 trans am with an auto trans i am new to auto trans i have only owned manual trans.when i am changing the tranny fluid i first drop the pan right? and empty the tranny fluid then this is the part i am confused on where is the bolt that i remove to refill tranny or do i just dump the tranny fluid in where the dip stick is in engine compartment?. thanks for your help.
Old Sep 15, 2005 | 03:41 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
you dump it down the dipstick.. also remember when you change the fluid to change the filter.. and be careful when you do that. if you pull the filter out and there is not a rubber O-ring on the end of it.. you have to get the o-ring out of the hole the filter neck goes into or you can cause some damage to your transmission.. filter's are really cheap too....
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
