?s about manual valve body
Old Sep 16, 2005 | 01:20 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
when i put the new engine and tranny in im gonna go with a manual valve body , so dont try and talk me out of it . I dont drive the car all the time and maybe it will keep me from driving it too since it might get annoying . But heres the thing , i dont need a tv cable do i since i control when it shifts. anyone got any info on this like , things i should know or like what parts the tranny doesnt have or any reccomendations.
Old Sep 17, 2005 | 11:26 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
You want to make your 700 manual or are you going to use a 3 speed?
Old Sep 17, 2005 | 11:55 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
im gonna buy a 700r4 with a manual shift valave body in it , i dont want a 3 speed , i still want od . I have an hour and a half drive to the track so i still want the od and my 4.10 gears .
Old Sep 17, 2005 | 03:21 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
where are you getting the tranny from? i would follow the recomendations of the tranny manufacturer. i would think it would dtill need it as it also controls fluid pressure, but the manufacturer could have fixed this inside the tranny.
Old Sep 17, 2005 | 05:57 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
well i dont know where im getting the trans from yet , im looking for someone reputable and one that will be able to handle 600hp on the spray and 450-500 na . So , i know it would be easier and cheaper with a 400 but i dont really want 3 speeds and then id have to change out the 410 s.
Old Sep 18, 2005 | 09:30 AM
Engine: 355 / 355
You would not need a tv cable with a full manual v.b. .. You may not want to hear this but a 700 may not be your best route with the kind of power you are making. You might want to look into a th400 with a gear vendors overdrive unit on it. That will give you some durability and still be able to hit the highway with your 4.10's. The 700 can be made beefy, but you are going to be pushing it when you are on the bottle.
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
lakeffect2
Aug 23, 2015 08:44 AM
crazynights
Aug 21, 2015 06:53 AM
Out-Cast
Aug 17, 2015 10:57 AM
