Do i need a clutch???
Old Sep 16, 2005 | 08:04 PM
alxtre99's Avatar
Car: 91' Camaro, 71' MERCEDES
Engine: Camaro 3.1L
i have a 85' Trans Am with a 5 speed borg warner i think it is, well the stock tranny... and im not sure about something, let me start from the begining... when i bought the car i noticed it had alot of play in the clutch and i didn't know if that was normal but it seemed to run fine but a month after i bought the car i started to grind going into fourth gear and it has always seemed to grind when going into reverse, someone told me i might need to get my tranny rebuilt cause they think the synchro's are going out but im not sure about it, but in my opinion i think i need a clutch cause reciently she started sliping in a couple of gears.... but i need another opinion so any help would be great... oh and if i do need to replace the clutch what would anyone recommend me getting as far as a replacement, should i get a stock replacement or think about an aftermarket clutch, thanks......
Old Sep 18, 2005 | 09:39 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
T5's always grind going into reverse, you can stop this by going into 5th before going into reverse. As far as clutches go we use 100% custom units here but if you have to go with a shelf unit I would definately stay away from centerforce. Ram is a decent clutch and so is hays.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
