Front Pump Removal
Old Sep 17, 2005 | 08:01 PM
kcee's Avatar
Car: 1984 Z28, 1995 LT1 Corvtte
Front Pump Removal
HOw do you ge the pump off the 700R4. Removed the bolts. What's next??
Old Sep 17, 2005 | 08:22 PM
ede's Avatar
ede
WAG slide hammer, do you have a manual
Old Sep 17, 2005 | 08:33 PM
kcee's Avatar
NO. I've looked locally for a Haynes Automotive Tech #10360 , which I read is the book I need. No one, including the library, had a copy. I read in my Helms manual for my Corvette, that a couple of Kent-Moore tools were needed, but that is par for the course with factory shop manuals. The Helms says to remove the solonoid and the filter first. The filter makes sense but the solonoid must be something for the 4L60E.
KC
Old Sep 18, 2005 | 07:40 AM
ede's Avatar
ede
never done a 700, but most i see have a pair of tapped holes for a slide hammer
Old Sep 18, 2005 | 07:57 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The solenoid(lock up) and filter must be removed. They both plug into the pump. The 700, unlike most other gm trans, does not use the slide hammer to remove. It uses a special puller that slips behind the larger set of splines. Then it pushes off the front input shaft to remove the pump. Most of the time you can put a pry bar between the rear of the pump and the top of the reverse input drum and GENTLY wiggle and pry them apart. If you pry too hard, or in the wrong place, you will damage the aluminum pump.
Old Sep 19, 2005 | 10:13 AM
kcee's Avatar
Thanks, Floor guy. I got the pump off. While I was pulling the pump, a filter fell to the floor. I'm guessing that this filter goes in one of the bores in the pump. Which end goes in the bore first?
KC
Old Sep 19, 2005 | 04:48 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The end that has the o-ring goes on the outside edge. Opposite the o-ring slides in first. Inspect the o-ring and clean the filter if needed.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
