Shifter stick kicks..
Old Sep 18, 2005 | 05:52 PM
straight's Avatar
Car: 1991 camaro + Dodge
I have a fresh new problem (annoying) My camaro has lost some power due to msd unplug but thats not the problem the real missing power is when im at a stop or red light even while driving sometimes...We i take off my shifter give a "KICK" Example: Gaz ....Bang! even when its shifts it give a small kick but the big kick is when im stop then push the gaz...When i push more than half it kicks when i barely push its ok..Fells like the drivetrain is lose or something ...cause when i hit medium size pot holes you hear something under the car bounce around i did a basic check to see if any lose NOTHING!!????Was told by a old friend its "KICK DOWN SHIFT" ?? was it that anyway..
Ive lost power because of this kick ive never had a Civic come that close to my rear end before...Thanks in advance..
P.S, its a 4 speed auto (OD)
Old Sep 18, 2005 | 09:44 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Most likely a broken trans mount, verry common on these cars. Put a jack on the tailshaft of your trans and it will probably lift right up off the mount.
Slap your friend upside the head. You have a 700R4 which doesnt have a kickdown, rather a Throttle Valve cable. Somewhat the same thing but not.
Old Sep 23, 2005 | 12:01 PM
straight's Avatar
cash is thight rigtht now , will it be hard to fix or expencive?
Old Sep 23, 2005 | 12:07 PM
4banger82's Avatar
Car: 84 camaro F41
its easy
all you need is a new trans mount. you can get one at auto zone for pretty cheap. just get a jack and put the car on stands. take off the cross memeber and unbolt the broken mount and replace. its really easy, shouldnt take more than an hour at most.
Old Sep 23, 2005 | 12:09 PM
straight's Avatar
ok thanks , dont have no auto zone here in montreal but ill look around for it ...Appreciate it
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
