85 iroc-z rear end swap
I have an 85 irockz and i'm stuffing a 454 into the engine compartment. i also wanna swap in a ford 9 inch rearend. is there a company that makes parts for this swap. any advice would be appriciated.
fenderwells need to be cut out and the suspension changed to a upper/lower control arm system. Also it looked like the firewall needed to be changed a bit. Also the front springs need to be replaced with something that can handle more weight. I mean its only 100 lbs extra or whatever but if you have ever had someone sit on the hood of your car while its moving you'd know it makes a big difference when driving.
I'm not trying to tell you what to do, I mean if you have the knowledge and skill to do it. Go for it, just be warned.
You can get plenty of horsepower and torque outta a smallblack.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
