I want a TC without a BUNCH OF B/S
Old Sep 24, 2005 | 12:08 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
i want a TH350 torque converter 3200-3500, and when i pull it into gear it snaps right into gear as if i didnt have a higher stall converter. im not sure who sells the best or one of the better torque converter but my 77 ventura has a 3k stall that takes off like its half way in gear/ as if it were standard. this is what im trying to avoid. anyone have an opinion about this?
Old Sep 24, 2005 | 08:07 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
my th350 with a B&M 2000 rpm stall snaps into gear. its from a tight new tranny not really the tc. doesnt mean the tranny is new just that it is in good shape. i like it lets me now i did a good job putting it together. im not to sure how you could aviod it.
Old Sep 25, 2005 | 11:58 AM
Car: 85 Camaro Z-28
Engine: 6.6
actually my ventura with the stock TC snapped into gear, with the new 3k stall it doesnt.
Old Sep 25, 2005 | 01:08 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Look into Precision Industries "Vigilante" torque converters. Even some of their hairier converters seem to have damn good street manners. Nice and tight until you stomp on it.
I've also heard good things about Yank converters.
A lot of the LS1 guys like them for that reason. I knew someone who had a 3500 from Yank and it was nice.
Be ready to crack open the wallet though, about $800 for one, IIRC.
Old Sep 25, 2005 | 01:53 PM
Car: 85 Camaro Z-28
Engine: 6.6
i think it would be $800 for a 700r4, th350 is probably less.... thats the type of converter i want tho. just not sure which would best for my money.
Old Sep 25, 2005 | 02:35 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Most of it depends on what stator the convertor has and fin angle.
You could get a sloppy 8" race convetor in there and never feel when the tranny is put in gear or shifts and probably foot brake it to 4-5K no problem. If the convertor is new enough, send it back to get it tweaked, most companies will retweak your convertor once for free since it's nearly impossbile to get it 100% correct 1st time out. Many companies that are good will get it close-very close, but if you want it exactly like you want it, it'll have to be tweaked.
Old Sep 25, 2005 | 11:31 PM
Car: 85 Camaro Z-28
Engine: 6.6
the one in my other car is fine because that wont be street driven very much, but in my camaro i want something that was stated above, you can feel it go into each gear.
Old Sep 26, 2005 | 02:28 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
I hear a lot of bad things about B&M white box converters I as well got the 2000 stall in my 80 malibu (no real use of putting it in as its only a couple more hundred rpm, shoulda went with a 3000 for myself) anyways with about 20,000k on the motor I need a new loead bearring I believe it is? those cheap 120 dollar TC ballon pushin your crank = bad times
Old Sep 26, 2005 | 11:38 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I have a Torco 9.5" convertor. Torco now sells under the Art Carr name. Its very tight and street friendly leaves from a light just like a regular convertor. I can footbrake mine to 2300RPM (my brakes SUCK) and it'll flash at like 3800-4000RPM. Call (325) 698-6667 and try to talk to Mickey. He'll ask you everything about your car and decide which convertor is right for you... Then $350 and less than a week later it'll be at your door step.
I gotta few friends who run these converters as well and we're all 100% happy - I'd buy another one in a second.
Old Sep 26, 2005 | 02:33 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
well i bought the 2000 rpm stall for my s10 and seeing how it was a cheap converter when i do motor work ill change it. the th350 cost me $300 then i bought a stock rebuild kit for $50, advance adapter kit for $150 and the b&M tc for $150 = $650 and me doing all the work including the rebuild. The only things i miss is my over drive and first gear. But i probly will end up going back to the 700r4 someday
Old Sep 26, 2005 | 10:14 PM
Car: 85 Camaro Z-28
Engine: 6.6
I noticed our cars run very similar times except i ran 2mph faster(1.69 60ft). those are some pretty good times, seems like your car cant pull to 6k like you were possibly shifting at with that cam. but i plan on swaping my 5-speed out very soon to a th350 so i wont worry about breaking it all the time. 700r4's are just way too expensive. im also switching my car to carb, because i cant set the timing because of the custom chip i had done is very screwy and the car doesnt run right at all.
Bubbajones_ya
Oct 25, 2015 08:01 PM
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Cleotiz
Sep 16, 2015 08:02 AM
