b&m megashifter + rw lockup at 75 mph??
Old Sep 24, 2005 | 08:10 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
i picked up my car today after having a .373 rear put in. everything was fine until i put the shifter into 1 and tried to go through the gears. i went to shift into D and the rear wheels locked up. it stalled the engine and i got to the side. i finally got it cranked up and put it into D and it was fine the rest of the way home. it has never done this before. does it sound like the shifter needs re-adjusting or what?
thanks
Old Sep 24, 2005 | 08:14 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I think it it had anything to do with the shifter cable you would have gone into Neutral or stayed in second.
Maybe you went way too far and hit reverse?
Old Sep 24, 2005 | 08:19 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
yeah sounds like the cable somehow made the tranny to go into reverse. id have a friend play with the shifter while you watch the tranny shift positions. hope you figure it out. but it sound to me somehow it skipped od and nuetral and went into reverse. i would be carfull till you sort that out. atleast you didnt wreck when the tires locked. good luck
Old Sep 24, 2005 | 08:22 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
b&m megeshifters have a reverse lockout that prevents that. when did you put the shifter in? make sure you put the cable into the correct hole or check the adjustment of the cable per the instructions. a rear end swap shouldn't have made a difference in the shifting of the shifter unless the shop that did it messed with it somehow. i can't see why they would.
Old Sep 24, 2005 | 08:34 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
no he put the shifter in 4th/od and the rear tires locked. im not saying the shifter itself skiped into reverse but maybe a miss adjusted cable allowed into reverse. but i think it could have been the bracket holding the shift cable to the tranny allowed the cable to shift into reverse. but this is just speculation because i cant look at it and see whats going on.
Elephantismo
Feb 13, 2019 12:51 AM
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
gt4373
Oct 8, 2015 10:37 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
