how much is too much?
Old Sep 26, 2005 | 06:30 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
how much power is too much for a recently rebuilt(less than 100 miles) T-5? I have a 350 with a mild cam. performer carb and intake, headers and mild porting. I just don't want to grenade this thing with a few power launches.
Old Sep 26, 2005 | 07:03 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Is it a w/c T5? Even so you will eventually blow it up with a 350. I'm running a w/c T5 that is freshly rebuilt, including all new gears, behind a strong 327 and I assume it will only last a couple years of limited duty, if I'm lucky.
Old Sep 27, 2005 | 06:03 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
mine is not a w/c. is there anything you can do to beef them up. or is it worth it to buy a richmond from summit and put it in?
Old Sep 27, 2005 | 08:10 AM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
just don't do any power launches and you'll be fine, or get another manual tranny like the TKO. Mostly like you will grenade it though from dumping it at high rpms. If you just fry the tires and get no traction it might not be that bad. I wouldn't expect it to last too long behind a 350 with upgrades though.
Old Sep 27, 2005 | 12:50 PM
Car: 2000 BMW M5
The non world class T5 is only rated at 265 ft lbs. You will blow it up running it hard. Making a non WC into a WC would require replacing everything internal - not worth it at all.
Old Sep 27, 2005 | 10:05 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
if a non w/c can handle 265lbs what can a w/c handle? also I have a chicken legger right now. but I have a posi 3.73 I am waiting to put in. will that kill my trans sooner? I just like to get into it now and then. I am not a 7k dumper. I like to fry the tires and get up to speed quick.
Old Sep 27, 2005 | 10:21 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
A world class is rated at 300ft lbs.
