Which Pro-Built is right for me?
Old Sep 27, 2005 | 12:28 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The GF's tranny is very long gone and we are looking to get a beefier one. As of right now its a stock 89 350 TPI with S-10 stall. Only mods we will add will be a 9lbs Procharger. Track time will be 1 or 2 weekends a year. Mostly for show and normal driving. I see the stage 1 is for 475 HP 2 is for 550 HP and 3 is for 650 HP
I've kinda ruled out the stage 3 already.
Old Sep 27, 2005 | 12:58 AM
Pro Built Automatics's Avatar
The Street/Strip unit with the HD steel sleeve & cryoed forward piston option should be what you need. You will need to go to a 9.5" lockup if you want this to last, your torque converter is to heavy & inefficent, and is hard on the drivetrain. The 9.5" will take off about 17 pounds of rotating mass off of the back of the crankshaft.
89gta383
Sep 4, 2002 04:55 PM
BuckeyeROC
Aug 14, 2002 09:20 PM
jigga27
Sep 22, 2001 06:04 AM
Gary 85IROC383
Jul 31, 2000 01:42 PM
