disassembled Very leaky T5-Front countershaft bearing almost falls out!
Old Sep 28, 2005 | 07:12 PM
88GTA3555SPD's Avatar
Car: 88GTA
Engine: 383
Transmission: t5 junk
the t5 out of my 88GTA leaked about a quart of gear oil a week...you could sit under the car and pretty much watch it drip right from the front countershaft bearing. So i pulled it all apart and i went to press the countershaft bearing out and it came out with very little pressure at all... and after pressing it out i can slide the front countershaft bearing in and out of the case very easily with my hands
a trans shop shop tried using RTV to seal the bearing in there a while back but it lasted about a month before it leaked again...
but i have another grinding T5 and im wondering if i should just swap cases????shouldnt that bearing be a tight press fit? or will loctite seal it? judging by how easily it slides in im thinking the outer part of the bearing might be spinning when i drive and causing a leak...with loctite fix this?????
Old Sep 29, 2005 | 11:43 AM
Car: 88GTA
Engine: 383
once again thanks for all the help guys
Old Sep 29, 2005 | 12:13 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Yes that bearing should be a very very tight press --- you should need a shop press to get it in and out. Replace the case
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
3.8TransAM
Oct 1, 2015 07:47 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
