T-56 Swap Question
Old Sep 28, 2005 | 09:45 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
T-56 Swap Question
I can get a 94 Z28, LT1/T56 w/110k miles on it for $1500. Car has a blown clutch. The tranny is solid as I drove it prior to the clutch going.
I am planning a T5 swap for my 87 IROC this winter but now this car is looking very enticing.
What parts from the tranny setup can I swap into my 3rd gen? My thought is probably the bellhousing, tranny, clutch, pressure plate, flywheel and hydraulics?
I'd probably have to get a cross member, torque arm mount, clutch pedals and the dakota digital box seperately. Not a big deal as I can part this car and make all the money back for sure!
Thanks for your input in advance
Old Oct 2, 2005 | 02:58 AM
JIMS406RS's Avatar
the 94 pedals will fit your thirdgen. everything else is correct.
Old Oct 2, 2005 | 07:11 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
you can use most of it for the swap. You will have to make or buy a trans crossmemeber. The flywheel may or may not work depending on if your engien is 1 or 2 piece rear seal. If its stock then it will work. Pedals will work with a few mods (do a search). stock driveshaft will work. https://www.thirdgen.org/techbb2/sho...aster+cylinder this is a good thread to answer alot of your questions...
Old Oct 14, 2005 | 01:59 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
If you decide not to do the swap, a friend of mine is looking for an inexpensive 4th gen T56 beater car...
theurge
Aug 21, 2015 12:46 PM
Hello, Michael
Aug 20, 2015 03:19 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
cRoe4
Aug 7, 2015 08:46 PM
