problem with tranny...i think
Old Oct 1, 2005 | 03:03 PM
mr. horsepower's Avatar
Car: 1989 Camaro RS
Engine: 5.0 TBI
Transmission: 700-R4
Axle/Gears: 3.42 open....3.73 posi soon
Heres the deal, i will be driving along with my car in overdrive, and it will hesitate and the rpms will drop from like 2500 to about 2000and then it will go back up, and when i am driving through a town at 25 it will sound like my car is chugging. It almost sounds like it is slipping but i cannot tell for sure. I don't know the signs of a 700r4 going to crap, so if someone could help me out that would be great.
Old Oct 1, 2005 | 03:22 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
sounds like you need to adjust your throttle cable. it is too far out(away from the firewall). this is causing your shift points to be way too low and it is trying to shift into od too early. it dropping from 2500rpm's to 2000rpm's sounds like it shifting into od(you didn't specify speed). the "chugging" at 25 mph could be the same problem. mine in drive at 40mph will only turn 2000rpm's. depending on your rear end ratio, you might be turning some low rpm's. for the most part, it sounds about right. just try adjusting teh cable some.
Old Oct 2, 2005 | 01:33 PM
Car: 1989 Camaro RS
Engine: 5.0 TBI
how do i adjust the throttle cable? It seems like all my shift points are screwed up...what causes this to happen cause one day it was fine, next day messed up. Thanks.
Old Oct 2, 2005 | 02:37 PM
87zjeff's Avatar
https://www.thirdgen.org/newdesign/tech/detent.shtml
this link shows how.
Old Oct 6, 2005 | 06:49 PM
Car: 1989 Camaro RS
Engine: 5.0 TBI
That diagram didn't really help me...it shows a 2.8, and mine looks totally different, well anyways, my car acts weird everyday...shift points are screwed up, the rpms jump at about 60 mph and it seems like the engine is missing, when the tranny gets warm it seems like my shift kit isn't even doing anything. I don't know what all this could be, are you pretty confindent that it is the TV cable? And one more question, do shift kits wear out? I bought the car with it so i don't know how long the life is on them. It works fine from shift 1-2, but after that it shifts normal and it seems like my car is slow as heck. Thanks for the input 87zjeff.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
