help with stall choice
Old Oct 8, 2005 | 10:28 PM
I-rocin's Avatar
Car: 87 iroc-z28
Engine: vortec tpi 350
Transmission: built 700r4
i just ordered my built 700r4, they're sending me a new stall to go with it, around a 2800 i believe,
would this be too much for an 87 350 tpi?
pretty much just catback exhaust is done
Old Oct 8, 2005 | 10:36 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
"I" think 2800 is too much for a stock tpi. Others will likely disagree. Something in the 2-2200 range would be better in my opinion.
Old Oct 9, 2005 | 11:21 AM
I-rocin's Avatar
Car: 87 iroc-z28
any other opinions?
Old Oct 9, 2005 | 11:52 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Nope, I still have the same opinion
Old Oct 9, 2005 | 01:04 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
put a little more power into the motor?
Old Oct 13, 2005 | 02:10 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Its not so much how much power, but where the power is made that dictates what stall is needed. Along with some other factors of course. If you havnt made any gear or vehicle weight modifications theres really no reason to go any higher than a stock converter. I also think 2800 is on the high side.
Old Oct 14, 2005 | 05:29 AM
I-rocin's Avatar
Car: 87 iroc-z28
the guy who i purchased the car from mentioned that he thinks that the gears are either 373 or 411, i believe they are 373s, i didn't know that made a difference in stall choice
Old Oct 15, 2005 | 11:01 AM
dankhound's Avatar
Car: 91 RS
A torque converter multiplys torque. The stall speed is just the speed where it is most efficient at doing that. When you swap to a lower gear(numerically higher), youve increased the mechanical advantage of the rearend. Thus less torque is needed to get the car moving. Therefore you can use a higher stall to in effect shift the torque curve up slightly.
Old Oct 15, 2005 | 01:22 PM
I-rocin's Avatar
Car: 87 iroc-z28
so if i have 373 gears, would a 2800-3000 stall be to big for a tpi, stock
Old Oct 15, 2005 | 01:25 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
yes
Old Oct 16, 2005 | 11:05 AM
dankhound's Avatar
Car: 91 RS
Try something a couple hundred over stock.
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
