700 Rebuild ques.
Old Oct 10, 2005 | 12:14 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
700 Rebuild ques.
I plan on having the 700 out of my maro rebuilt its just a 2.8 but the guy wants to run the trans through the performance garden(ie vette servo, 10 vane pump, etc..) do i really need all that? He says it will help it live longer. The car is gonna be going from coast to coast and back next summer so if it will help i might as well go for it right?
Old Oct 10, 2005 | 12:17 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Shift kits and all that will help it live longer due to the lack of slippage between shifts but behind that 2.8 i dont think the trans will die very quickly anyways.
Old Oct 10, 2005 | 05:18 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The upgrades mentioned are cheap and well worth it.
Old Oct 10, 2005 | 07:43 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
ok thanks guys. He is talking about 1100 for the rebuild and removal and install. Sound about right?
Old Oct 10, 2005 | 08:53 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
If that price incldes a remanufactured torque converter, and a cooler flush, it sounds very fair.
Old Oct 10, 2005 | 09:21 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
it does include the TC but didn't ask about the flush
Old Oct 10, 2005 | 09:25 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Most shops flush the cooler. The smart ones do, anyway. Any crap or metal debris trapped in the cooler or lines will be pumped into the new trans.
Old Oct 11, 2005 | 04:10 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
they have a pretty good warr. so i assume he would flush it to protect himself
Old Oct 11, 2005 | 04:14 PM
Ask; don't assume.
Old Oct 16, 2005 | 06:02 AM
Pro Built Automatics's Avatar
The 10 vane setup is stock in your case already, the Vette servo is less than $23.00 with the latest updated seals. Make sure you get a 7 or 8 Borg Warner Hi-Energy 3-4 clutch pack, Borg Warner Hi-Energy 2-4 band, Trans-Go Performance Shift kit, Trans-Go No Yo-Yo steel front pump rings & priming spring, GM hardened sunshell, large main boost valve .500" or .471", & intermediate/reverse boost valve .296", turbulator steels for the low/reverse & reverse input clutch setups. These are a minimum for a "good" performance setup.
Old Oct 16, 2005 | 10:24 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
do i have a 10 vane? he said cause it is bolted to a 2.8 it only had a 7 vane pump.
Old Oct 17, 2005 | 09:17 PM
The 7 vane setup was used in the early 700R4's. Yours is a 10 vane setup, unless someone changed it on prior rebuild.
Old Oct 17, 2005 | 11:26 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
ok thanks for the help
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
