Stupid TV cable question, but I'm lost
Old Oct 14, 2005 | 12:39 PM
TurboGM1's Avatar
Car: 89 RS Camaro
Engine: 2.8 TPI
Ok, I know where the TV cable is, and what it does, what I don't know is how to adjust it. Can someone help with this? This might be a part of, or THE problem with how the car has been running and shifting (or not shifting at times). Everything I've read on the threads about this problem comes down to the engine breathing (new PVC, EGR, filters, IAT, vacum lines), the fuel flow (new fuel filter, TPS, IAC), spark (also new cap, rotor, plugs and wires), or the tranny itself. I know it needs a tranny mount, and a filter change. With everything else beinging replaced or cleaned up, my last resorts are timing (getting done this weekend while doing tranny work), injectors, fuel pump, adjustments, or the computer isn't sending or recieving signals properly. I've done everything I know how to do, and each part replaced or cleaned has helped it run better, but the dieseling, loss of power, irradtic idle at times, and hard shifts or not shifting at all in high rpms (3,500 and up) is a pain in the A$$! Please help so I can do this this weekend. I don't want to bring it to a shop for something I can do myself. Thanks
Old Oct 16, 2005 | 12:09 AM
Nordbert's Avatar
Cheeck out www.tvmadeez.com. It has the info you need to
do the job right.
Old Oct 17, 2005 | 10:23 AM
TurboGM1's Avatar
Car: 89 RS Camaro
Engine: 2.8 TPI
Thanks man, good site, lots of info on this. Now maybe I can get this thing to shift up and down properly
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
