10 bolt questions: 4th gen posi and axles, and misc ?s
Old Oct 21, 2005 | 09:28 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Buddy of mine at work has got 2.** posi out of a ~94 LT1 Camaro. I pulled out my axles on my 3.08 and found that I hace the dreaded 26 splines . So, could I get stock/aftermarket axles for a 90-92 with 28 splines to fit the carrier? Arent 90-92 and most/all 4th gens the same as far as carrier goes? I mean, I know I cant use 4th gen axles in my 3rd gen housing, but I just wanted to make sure that axles from a 90-92 would fit into a 4th gen carrier.
Another thing, why is it that everyones saying you must use a 3 series carrier when upgrading to a 3.73 gearset? What about the richmonds for the 7.625", 3.73 gears made for a 2 series carrier. Is there any negative effects of using a 2 series carrier with 3.73s (as long as the gears were made for 2 series)? Seems to me that the ring gear would be thicker, meaning possibly stronger?
PLEASE, one more thing. What exactly is the difference between the 7.5" and 7.625" 10-bolts? 7.625" from a 4th gen? If so, can the internals be swapped out between the 2, other than axles? Ive yet to find an exact answer to this question.
Old Oct 22, 2005 | 04:16 AM
ede's Avatar
ede
yes you can swap axles and use the 4th gen carrier. what you see with the richmond gears, and others maybe, is a set of gears not made to stock thickness. they're made thicker to move the ring gear into the pinion so you can run a 2 series carrier. if you have a 2 serires carrier i tihnk the smarter way to go would be to run a spacer on the ring gear so your 3 seriers gear set woukld work on either. there is no differance between a 7.5 and 7.62 ten bolt other than gm wanting to confuse all of us with the name change.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
red90IROCls1
Aug 25, 2015 06:56 AM
3rdgenparts
Aug 5, 2015 11:57 PM
