TV Cable problem I think...?
Old Oct 24, 2005 | 08:16 PM
ammoblows's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 350 HO 4bbl
Transmission: TH350
I just got done performing an engine swap from a 305 cfi to a 350 4bbl, got it all set up with a little bit of pain from the tv cable not reaching the holley I got under the hood. Bought a bracket that was suppose to fix the problem but only helped it out a little bit...cable still needed to be about two inches longer in order to reach carb. I made a linkage so that the cable reaches now...I got in the car, fired it up, dropped it into gear and down the road I went...1st, 2nd, 2nd, 2nd still...at 4500 rpm and crusing at a steady speed I figured that it was not going to shift to 3rd for me. Could it be I have not got the cable adjusted correctly or need a new one? The cable should reach without having to make extra parts in my garge I would think...does anybody know where I can obtain an oe cable for pretty cheap and in a hurry? I figure I will start there and then move on to the tranny until I can locate the problem. Hope someone can help me out here. Thanks in advance.
Old Oct 25, 2005 | 12:54 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
two choices:
Stock or http://www.tvmadeez.com/
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
