Rear-end swap drum to disc need info
Old Oct 28, 2005 | 08:15 PM
Purity's Avatar
Car: 1984 Camaro Z28
Engine: L69 H.O. 305
Transmission: Automatic 700R4
Ok I'm swapping my rear end from a drum set up to a reare end with disc. its 1984 z28 not sure what year the doner rear end is out of but I know it was an IROC.
I was wondering if anyone knows what I'll need as far as a a conversion kit ot lines hard/soft, master cylinder that sort of thing.
I'd really appreciate your help.
Old Oct 29, 2005 | 07:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are many threads on the site concerning such swaps. You might consider a search. I think you'll find all that you need.
JamesC
Old Oct 30, 2005 | 06:49 PM
Purity's Avatar
I searched it and found most of what i needed I was just looking for info on if i should use hardlines or can use sof lines in place of them. And if the lines were similiar enough to use the Drums lines on the disc?
Old Oct 31, 2005 | 04:30 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
I know you won't be able to use the same rear brake lines. you need the rubber lines for both calipers if it is from a newer camaro with aluminum calipers. The steel calipers has one rubber on on the drivers side and a hard line on the drivers side. Your e brake cables will be different also. Also your j block will need to be replaced and depending on rear 16" wheels. If you don't already have them.
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
