another tc lockup question
Old Oct 31, 2005 | 01:58 AM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
I've read about two dozen posts asking how the torque converter lockup switch worked, and I know this is posted a lot, so sorry if this is redundant.
I installed a torque converter lockup switch on my car using the tech article instructions, but then read a few things saying that it would probably put a lot more wear on the converter, so I hardly ever use it. My question is when I have the switch off (like I almost always do), and the two terminals are not connected, does it disable the tc from its normal function or does it just function normally unless I flip the switch and manually override it.
I'm just hoping that having the switch there doesn't interfere with it's normal function, and that I'm not wasting gas - it doesn't seem like just having the switch there not turned on it would affect it.
Thanks for any help!
Old Oct 31, 2005 | 01:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
With the switch turned off the TCC works as the computer tells it to.
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
