what 4 speed in an 82 Z28
Old Oct 31, 2005 | 03:12 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
Did the 82z come with the super T10 trans? Is it the same all aluminum one used in 80-81? I am looking at an 82 and I couldnt see underneath well enough to do an ID but the trans looked to be aluminum.
Old Oct 31, 2005 | 03:23 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I really wouldn't know, but if you want to find out it it's aluminum take a magnet to it.
Old Oct 31, 2005 | 07:48 PM
drptop70ss's Avatar
Car: way too many
Thanks, I know how to ID aluminum I just want to know what trans was factory installed. I cant get under the car with a jack for a few days so I just wanted to know what should be there.
Old Nov 1, 2005 | 01:24 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Could either be a Super T10 or a Saginaw.
Not the same as the earlier model T10s '81 and prior...only has a 27 spline output shaft (versus 32) and the tailshaft has the torque arm mount.One year only trans.
Old Nov 1, 2005 | 01:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
guys! making this harder then it has to be...
I have the T-10, and from what i've heard, the easy way to tell is.... -> where is reverse?
top left is T-10.
bottom right I think is saginaw,.
Old Nov 1, 2005 | 07:01 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
top left is T-10.
T10:
R 1 3
-- 2 4
Old Nov 1, 2005 | 08:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
I was just gonna say, I know there's another active member with a T-10, air_adam...
hey adam, did you re-use the stock 305 flexplate when you did the 350 w/ t-10? I'm doing up a new motor, and i'm trying to figure out what i'll need to buy... 153 tooth?
oh yea, do you have a shifter for that too?
Old Nov 2, 2005 | 07:49 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
..and I quote "Did the 82z come with the super T10 trans? Is it the same all aluminum one used in 80-81?"
..and in another post " I just want to know what trans was factory installed."
I specified that 82's came with either the T10 or the saginaw factory installed.That T10 is a different trans from any other year T10 like he also asked in the ways that I stated.
I also own a factory T10 car..so I would hope I know a little on the subject.
Old Nov 2, 2005 | 10:32 PM
Air_Adam's Avatar
I haven't yet installed my T10, but from what I can tell, the flywheels for the T10 and T5 are the same. I have both, and the only difference I can tell is that the flywheel thats on the 350 now (with T5 still attached) is aluminum, and the T10 flywheel is steel.
I'll be reusing my aluminum flywheel when I install the T10.
I also have the factory shifter for the T10. Its a pretty crappy shifter, lol
I know that Hurst makes a Competition Plus shifter and an install kit for both the T10 and the Saginaw 4-spd trans' in these cars. I plan to get one of those before I install it.
Really, the only reason I haven't installed my T10 yet is that I can't find an '82 torque arm around anywhere. Any '82 torque arm will work... one from either 4-spd, or an auto. I just can't find one.
Old Nov 3, 2005 | 07:47 AM
drptop70ss's Avatar
Car: way too many
thanks guys, I will be looking at the car tomorrow. This car has been messed with and is pretty much a parts car, so Air Adam if I get the car the torque arm will be for sale. I will be using the T10 in another car and wont need the torque arm.
Old Nov 3, 2005 | 08:23 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Lengthen yours 2 1/4".
83 and up TA's are 55"..82's are 57 1/4".
I am selling Hurst shifter and trans in the classifieds.
Old Nov 3, 2005 | 09:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
I have a hurst shifter on my car, came with it...
I'm pretty sure i've seen '82's in the yards around here, if you're in a bind I might be able to help you out, greyhound one to you or something.
deracer
Apr 11, 2016 12:04 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
19irocz85
Aug 26, 2015 07:54 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
novaderrik
Aug 10, 2015 12:44 PM
