700r4 light throttle, high rpm shift
Old Nov 1, 2005 | 01:02 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Ok, took the T/A out for its first real drive... Rebuilt 700r4, new crate 350, rebuilt QJet, etc.
I have adjusted the TV cable as per BowTie and Haynes/Chilton directions.
Light throttle shifts from 1-2 at almost 4k! WOT, about 5200 (only done it once or twice, still breaking in). If i cruise to 3k, and lift throttle it will shift. Downshifts work (3-1, 2-1). 4th only engages above 50...
Pressures were within tolerance...
Any ideas?
Old Nov 1, 2005 | 10:31 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
how far have you drove it? sounds like normal break-in of a performance 700. the valves could be sticking a little if the tranny was assembled without any oil in the valve body. did you buy the tranny or rebuild it yourself? what was done during rebuild as far as mods go?
Old Nov 2, 2005 | 10:58 AM
Car: 85 Trans Am
about 200 miles
The tranny was dry when i got it. Purchased. Mostly a "high quality" rebuild. Little better than stock.
TV cable, as said, is adjusted and working fine. Appears to bottom out the plunger at wot, when compared side by side, disconnected.
If i let it go its course, light throttle, it has a firm, non-agressive shift. at mid-mid/hard throttle it is firm to the point of chirping the tires.
So no worries yet?
(BTW: I have never driven a car with a 700r4, nevermind, all those miles are the first ta/camaro ive driven...)
Old Nov 2, 2005 | 12:04 PM
87zjeff's Avatar
i wouldn't worry about it. mine goes to around 4000rpm on a medium take-off. at wot, it will be around 5000 or so.
jklein337
Sep 19, 2018 06:23 PM
maroe624
Apr 16, 2017 08:29 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Omega
Aug 10, 2015 12:46 PM
