GM or Parts Store for Slave Cylinder
Old Nov 2, 2005 | 02:11 PM
smithtc's Avatar
Need to replace my Slave Cylinder for BW T-5. Do I need to order through the GM Dealership or is the local Car Tech brand going to be sufficient?
Old Nov 2, 2005 | 02:56 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
From GM the slave, master, hose & reservoir come as one unit. List= $196.08. GMpartsDirect.com will be less.
Old Nov 2, 2005 | 02:58 PM
smithtc's Avatar
Appreciate the response...
The local GM Dealership quoted me 86.95 on the Slave Cylinder...but is it better than what I can get at an Advanced AutoParts or Cartech Auto Parts, etc.?
Old Nov 2, 2005 | 05:48 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I got my slave from Advance Auto, about $45 for it.
Took me about 2-3 hours to change mine (should have only taken 20 minutes or so). Mine had the pin rusted/stuck so I had to carefully cut the slave apart to get the pin out and I didn't want to remove the hydraulics from the car.
I had to drive the car 30 miles home with no clutch, makes for an intersting drive, especially if you have to stop often.
Old Nov 4, 2005 | 10:15 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
gmpartsdirect t-5 part # 12527718 t-56 part #12559912 120.00$ shipet
Old Nov 8, 2005 | 07:49 AM
smithtc's Avatar
Living in a small Alabama town, I guess prices are cheaper here.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
1nastygta
Aug 8, 2015 07:38 PM
