Installing SPEC stage 3 HELP!!
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
OK here is ny issue. I have a brand new 383 that I ust put it. I installed my custom flywheel with ARP bolts and toqued them down. So far so good. Then I grabed my clutch disk, "tip" bearing and preassure plate, as well as my ARP "pressure plate" bolts. I lined it all up and got ready to try and slide in the first bolt and to my amazment, they are WAY to short. The bolts can't even go throught the damn metal housing of the pressure plate.
-Where can I get the right bolts?
-How come my so called "pressure plate" bolts didn't work? (most likely cuz the housing is much thicker)
-How much do I toque them down once I have them?
-Are genric bolts bought from a hardware store gonna work allright?
Any help would help greatly, thanks
DO NOT use "generic" bolts!!!! Unless of course, you don't like your feet, and would like to do away with them.
Clutch bolts have a special "shoulder" sort of area between the head and the threads, that acts as a sort of "dowel pin" to locate the clutch on the flywheel. The shoulder goes about 1/4" down into the flywheel; it looks and works alot like a starter bolt. The threads don't begin until qbout 3/8" below the flywheel surface.
What parts are these? Is this stock-style LT1 T-56 stuff? If so, regular clutch bolts won't work, you need ones for a 93-97 LT1 T-56, which are different from any others I have ever come across.
Torque goes with hardware size; in clutches, the same as anywhere else. Correct torque for clutch bolts (3/8"-16) is usually around 35 ft-lbs.
Engine: LS3
Wow thanks for the help
Think I should just go to a chevy dealership and grab some T-56 bolts for a 94 F-body? I have no idea where I can get my hands on these bolts. I will follow your recomendation on torque setting too. Thanks again.
Now where can I get those bolts.... hmmmm????
Think I should just go to a chevy dealership and grab some T-56 bolts for a 94 F-body? I have no idea where I can get my hands on these bolts. I will follow your recomendation on torque setting too. Thanks again. Now where can I get those bolts.... hmmmm????
Dealer should be an option; Summit & Jeg's & Thunder Racing etc., your local speed shop, local drive line shop, might also be places to check.
Engine: LS3
i keep looing through jegs and summit. But can't find anything. Even online. There are no shops neer me (that I know of) I will make some calls I guess. I think that GM is my best bet now. Thanks for all the help
Engine: LS3
Free Bird...... loc-tite.
Not sure I see why you said that.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I would suggest some 272, you dont want them feet falling off on ya
Definately get the right bolts, feet are nice to have. Also be a pitty to see a trashed car because of something like that.
Engine: LS3
i found a dealership that is 5 minutes from here that has stock replacment ones I am picking up.
Damn they onlyhave 4. They have to order more. Oh well. They will have them tomorow.
And yes I was on the phoe with them as I was typing this, hehe.
There's been some pictures running around on the Net lately of a car that enjoyed a clutch explosion. I'll have to see if I can find them. One look at what happens, and you will never even think to half-*** a clutch again, you can believe that. Last edited by sofakingdom; Nov 4, 2005 at 01:15 PM.
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
This is NOT a joking matter get it right. I just installed a Lakewood Blow proof bell housing. Because I am planning on using nitrous don't want any issues
By the way the install is a PITA
Direct fit bolt in my @##
Engine: LS3
Ok guys, I am aware that it is not a joking matter. I just bought my 4 bucks a pop GM pressure plate bolts. They are in and the cluth is on. Thanks for all your help and concern.
toronto formula
Nov 10, 2015 06:17 AM
