can you use the same converter for all of these as long as the splines are right (30)
88 700r4:with: 4l60e converter???
TCI-243105
TCI-243105
yes. i used to run a 4l60e converter in mine. i think the only difference is the clutch material. i think it may have had a slightly higher stall as well.
ZZ4 86 Z28
close
- Join DateJul 2005
- LocationRockville, Maryland
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1986 Z28 Camaro Gunmetal Gray with
- EngineGM Crate ZZZ HO 350, Edelbrock head
- TransmissionRebuilt 700r4 all TransGo and Beast
- Axle/Gears10 bolt with 3.73 gears
- Liked:1 Time in 1 Post
what are the different spline counts for different years. i am trying to sell a 2500 converter that fit onto a 90 trans, and somebody wants to know if it would work on theirs.
evrythnig '85 and later were either 27 spline or 30 spline. all v-8's are 30 spline and i'm not positive about the 4.3 liter.
In mid 1984 they went from 27 splines to 30 splines.
the smaller 6 cyl. 700r4's still used 27 splines. what changed in '84 was the size of the front pump bushing.
ZZ4 86 Z28
close
- Join DateJul 2005
heypro built automatics...does your user name have anything to do with a business you might run. because im looking for a new tranny.
i know Pro builds deals with lock up converters, pm with a price on a 3500 stall.... smaller the better right ?(9")
3300lbs formula w/o me (200)
350 HSR
268hrx Nitro HP cam 224/236
50/50 street/strip
350 HSR
50/50 street/strip
