T-5 swap crossmember question
Old Nov 6, 2005 | 02:00 AM
berlinettakid's Avatar
Car: 86 T/A, 86 z28, 79 berlinetta, 69 chevelle (totally rusted)
Engine: 350's in the f-bodys. 327 in the works for the T/A, MIGHT go with a 383, none in the chevelle
Transmission: T/A has a 5-speed, z28 has a 700-r4, th-350 in the 79' (5 or 6-speed soon), and none in the chevelle
Is there a difference between manual and automatic crossmembers? Or is there a difference between a base models crossmember and a Iroc/GTA crossmember? I've done this swap once before with two base model firebirds. My problem on this swap, a T-5 from a base model firebird, into an iroc, is the crossmembers.
The orignal iroc automatic crossmember has two rubber bushings between the crossmember and a top miniture crossmember thing that the tranny actually attaches to. which would put the back of the tranny about a 1/2 inch higher. I'm thinking this is to make the driveshaft angle better for the irocs lower rear suspension. but i'm not sure as i've never seen this type of crossmember before. All the other ones i've dealt with are basically a flat piece of steel, none have had bushings and two main pieces of steel (trying to give an idea of what i'm dealing with???)
btw both cars are 1985's,
thanks.
Old Nov 6, 2005 | 09:03 AM
4banger82's Avatar
Car: 84 camaro F41
i recently swapped a 4 speed for a T5 in my camaro. i had to trace and cut my crossmember to make it fit correctly. also, the T5 sits at an angle so you have to make that work.
Old Nov 6, 2005 | 02:43 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
you just have one of the ... 'weird' crossmembers
i dont think it makes it sit much higher because i think the bottom peice slopes down more, but im not sure
id just say find the other crossmember but it seems like there less common then i thought for some people
Old Nov 6, 2005 | 04:14 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here you go:
https://www.thirdgen.org/techbb2/sho...hreadid=327912
JamesC
Old Nov 7, 2005 | 09:53 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I used the same crossmember from my auto with my T5, it was the flat one piece crossmember.
It looks just like the one on my old 86 Trans Am,
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Elliswon
Aug 10, 2015 12:33 PM
