LS 4l60e pump in a 700??
Old Nov 6, 2005 | 10:22 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Well I went through my tranny this weekend and decided to put a 13 vane kit in the pump. Well after opening it up and replacing the parts I then read that I need a clamp to keep the pump lined up. Well I cant get a clamp and I have a pump from a 4l60e out of a '00 silverado. Are the pumps different from the LS motors? I havent counted the splines yet.
Old Nov 6, 2005 | 10:36 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
yes, the pumps are different. the main difference being the filter opening. the 700r4 pumps had a better boost control assembly. i have never used a clamp to line up the pump halves. it can be tricky, but you can do it without it.
Old Nov 6, 2005 | 10:40 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I wont swear by it but it almost looks like 1 half of the pump is oblonged a bit!! The pump was in working order but me being me, I decided to upgrade it since it was out.
Old Nov 6, 2005 | 10:48 PM
87zjeff's Avatar
oblonged?.......lol. i have never seen that in all the pumps i have seen(and that is a bunch) i always use my fingers to line up the edges once i get the bolts close. i guess the oblong look could be from the slight misalignment. doing it without a clamp helps if you have someone helping you. use the bolts to get the 2 halves of the pump close together(just touching), then use your fingers to mimic a clamp to align the pump. then have your helper snug the bolts, then torque them.
Old Nov 6, 2005 | 10:51 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I think I might try it again , but if it doenst align then im gonna take it to a tranny guy.
Old Nov 6, 2005 | 10:53 PM
87zjeff's Avatar
lol....ok. btw, leave the o-ring off the pump while you are aligning it so it will not be in the way.
Old Nov 6, 2005 | 10:55 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Put a couple of large hose clamps together to make a band clamp for aligning the 2 halves.
Old Nov 7, 2005 | 05:24 AM
Pro Built Automatics's Avatar
The 4L60E will not interchange with the 700R4 in terms of the front pumps. Stick with the 10 vane setup, the 13 vane will take away volume, & has no advantages. I use the 10 vane in "all" my performance buildups.
Old Nov 7, 2005 | 04:19 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Well I went back and tried to install the 10 vane parts back and its being a PITA !! . It just wont go back in and feel right as far as the vanes, you can get over half in and they dont have enough room to slide in. Doent seem right to me. Whos a good company to buy a rebuilt pump from?? You can see some wear on the vanes so I see it being pointless puting them back in and wanting this tranny to last with want I will put it through.
Pro Built Automatics, I went to your site and didnt see any, do you sell them?
Old Nov 8, 2005 | 06:18 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Well I took some time and acessed the situation today. ummm what did I find, I was trying to put the vanes in wrong. I opened up the 4l60 pump and saw how it was put together. After that it went together nicely. Thanks for the help yall !!
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
f-bodyz28
Sep 2, 2015 05:03 PM
C409
Sep 1, 2015 03:42 PM
