700r4 info needed
Old Nov 7, 2005 | 12:17 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
700r4 info needed
I have a couple of questions about the 700r4. First what hooks up to the 4 prong connector on the transmission?
Second what years are better? I heard something like the pre 88 wasn't any good is this true?
What would be a good shift kit? I want one that will let me really feel the shift.
Finally is there a number somewhere on the transmission so I can identify exactly which tranny I have?
Brad
Old Nov 7, 2005 | 02:13 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: 700r4 info needed
Brad
4 prong is lock up wiring
87 1/2 and up is better
b&m is my favorite, most prefer trans go
pass side of the trans, stamped just above the pan is a code used to decipher the info.
Old Nov 7, 2005 | 02:50 PM
3rdgenmaro's Avatar
Car: 88 IROC
thanks for the help
On the lock-up, does it have to be hooked up? If I do what do I hook it too? I cant find anything that even looked like it came from it out of the car the tranny came out of.
Is there anything else I can put into the tranny to try to get it to perform better and last longer? Like a bigger TV valve or the Corvette Servo? What exactly do these things do? Can you even feel a difference?
Also once I get the number from the trans, Where can i go to cypher the number? Is there a list on here?
Thanks again
Brad
Old Nov 7, 2005 | 05:58 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
vette servo, .500 boost valve, hardened sun shell, kevlar bands, 9 clutch pack, modified governor, i could go on for ever.
Old Nov 7, 2005 | 09:02 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
thanks for the help
Thanks again
Brad
Lock up should be hooked up. It is better for the trans and gives 2 or 3 mpg.
There are dozens of things you can do to beef up a 700r4. How much power you make and how much you wish to spend are relative.
Post the code and I will break it down for you.
Be sure that you have a 700r4. 16 bolts hold the pan on. It is rectangular, almost square and does not have any noticable humps or notches in the perimiter of the pan.
Old Nov 8, 2005 | 04:47 PM
brutalform's Avatar
Can you break down my code? Qx%90$!=__%4Lbsa~~
Old Nov 8, 2005 | 09:33 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Sure brutal,
qx= prototype
%90= January 1980
$!=_ extra low 1st gear ratio
The other number are internal Mopar codes.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
TreDeClaw
Aug 14, 2015 06:58 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
