TCC not engaging
Old Nov 10, 2005 | 10:20 AM
87z28fromhell's Avatar
Car: 87Z
Engine: top secret
Transmission: top secret
TCC not engaging
Okay here's the deal, I bought this camaro and the fans come on when the ignition is turned on. The tcc has never engaged. I believe this to be because the engine never reaches 190. So the end result is that the tranny is now toast. When I get my car back from the shop what should I look for when diagnosing the tcc problem? i.e. why are my fans hardwired to the power with the key on? What should I look for, a bad sensor or relay? If said relay or sensor is fixed and tcc still does not engage what now? I have skimmed a few post on the toggle switch method about total control of the tcc where it engages in 2 and 3 gear, will still engage in 4? Stupid question I know. My ADD is kicking in and I do not want to search through a millions threads at this time. A simple answer is all I can concentrate on right now. OK so I am lazy, just hook me up. Thanks. Peace out.
Old Nov 10, 2005 | 10:37 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
With key on (ignition power), Test terminal "A" on the connector. It should have 12volts
Old Nov 10, 2005 | 11:52 AM
Car: 87Z
Engine: top secret
uhhhh what terminal? on the tcc wiring?
Old Nov 10, 2005 | 11:55 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Of course on the tcc wiring connector. Terminal A.
Old Nov 10, 2005 | 12:14 PM
Car: 87Z
Engine: top secret
any advice on the fans?
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Elephantismo
Feb 13, 2019 12:51 AM
92camaro350cci
Oct 14, 2015 09:29 AM
ramicio
Sep 28, 2015 01:18 PM
sahlomonic
Sep 20, 2015 07:15 PM
