TC Lockup? How to tell if it does?
Old Nov 12, 2005 | 01:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
How do you know if your torque converter is locking up like it should? Will RPM's change a noticeable amount?
In my 1992 I just swapped in a 350 carbed motor, removed ECM, and installed a lockup kit in the tranny that is supposed to be vacuum operated. I'm not sure I can feel or see anything happening in my stock 1990 when it locks. How do I tell if it is working?
Old Nov 12, 2005 | 02:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I believe the RPMs drop somewhere in the neighborhood of 500 when it locks.
What lockup kit did you use?
Old Nov 12, 2005 | 05:23 PM
Car: 1992 RS
Engine: Carbed 350
I got the TCI kit, part # TCI-376600.
Old Nov 18, 2005 | 12:24 AM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
When it locks up, it almost feels like another upshift, so if you were to count from a stop to highway speeds, you would feel 4 distinct "shifts" 1-2, 2-3, 3-4, and 4- lock up.
Old Nov 22, 2005 | 10:07 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Another way to check:
If you meet the conditions that cause a TC lockup (cruising in 4th at part throttle), keep the throttle at the same position and lightly press the brake pedal. If the ECM gets the brake signal it will cancel the TC lockup and the RPMs will go up.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
illegal87
Mar 29, 2001 07:38 AM
