stock shifter
Old Nov 12, 2005 | 08:41 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
stock shifter
how do you manually shift a auto with the stock shifter? do you need to push the **** to go thru 1-2-d-overd?
Old Nov 13, 2005 | 09:53 AM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
yes you do need to push the **** in to manually shift the trans. but i heard its not good for the trans unless you have work done to it. like a shift kit or shift improver kit. shifters like b & m also make shifters that are made especially for manually shifting an automatic.
Old Nov 13, 2005 | 11:00 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
It is very easy to over shift with the stock shifter.
B&M makes a nice shift plate for the stock shifter that makes it very easy to use, much like an aftermarket gate shifter.
And its only like $25 bucks.
Old Nov 13, 2005 | 02:35 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
im going to get a megashifter very soon. Do you need to pull the triger to shift or is the triger only to get out of P and R
Old Nov 15, 2005 | 09:49 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the trigger is only out of park and drive. you cannot go into reverse from any forward gear with a megashifter without pulling up on the t-handle/trigger.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
Genopsyde
Oct 7, 2015 08:35 PM
NBrehm
Aug 25, 2015 11:49 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
