Can I use an 86 truck 700r4 in the bird?
Car: 89 GTA
Engine: 350 tpi
My main question is will it be worth my time or should i find a newer bird tranny. I just smoked my trans and am on a limited budget and can get a 700r4 from an 86 full size truck for cheap if i pull it. What will i need to change to make everything work properly, and is there any downfall to the older truck tranny?
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
mid 87 and up they are built tougher. The sprag is 26 element. Newers are 28. Lo roller clutch is bigger on newer ones as well. You can make it work, but newer is better to start with.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
he is correct. the newer models 87 1/2+ have many updates that the previous models did not.
yes you can use the truck trans in the bird just swap the tailshaft housing, trans mount and gear select lever. use it for now and rebuild the original tranny when funds permit.
Car: 89 GTA
Engine: 350 tpi
I actually just came across one in a 91 van with a 350 for a little bit more so i think im gonna go with that. Any issues i should be aware of?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
on the 700r4 one yes it is identical externally from a truck as it is from a car too
the tailshaft housing is really the only difference,
all the 700r4 are the same length escept for the vette ones a little over an inch shorter- an oddball length
what trans is in the van?
th350 ?
6" or 9" tail in that ?
what trans was in the bird ?
better make sure youre putting in same length trans or youre gonna not have a driveshaft anymore,.,
good luck
th350 ?
good luck
Car: 1988 IROC-Z
Originally posted by mystikkal_69
yes you can use the truck trans in the bird just swap the tailshaft housing, trans mount, tv cable and gear select lever.
Engine: 4.3L Z TBI
Originally posted by Dan8289gta
700r4 in both, can i just swap tailshaft housings?
