why do these cars go into gear so hard?
Old Nov 15, 2005 | 11:53 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
is there a reason for that? mine clunks real loud into reverse but not drive. when i go into drive though it goes so hard the car moves and kicks stones..a little. is all that normal? all 3 of my thirdgens ( 2v8s one v6) have been like this but mine seems worse. its like im not holding down the brakes all the way..but i am. if it was a broken mount (common right?) would that be doing this? if not treated could this hurt the trans?
Old Nov 16, 2005 | 07:04 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The 87 1/2 and up transmissions had an aux valve body added. This help to reduce this. Pre 87's bang pretty hard sometimes. Later are not too bad.
Old Nov 16, 2005 | 07:39 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Well what he said plus +
Wear in the trans will cause this
Doing it right after engine started will do this(idle high)
Improperly adjusted rear brakes will do this
Broken trans mount? U betcha will do this.
Improperly adjusted idle (aka TPS and IAC will cause this)
Vaccum leaks(high/er idle)
Check your trans mount and gi thru all the IAC/TPS setting procedures and see if this helps out any.
Some of it wont go away, but u shouldnt bang into gear all of the time
later
Jeremy
Old Nov 16, 2005 | 08:43 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Might explain mine, it does'nt bang , but you sure know its selected ok.
Old Nov 28, 2005 | 02:25 PM
drews91maro's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
also check the TV cable make sure it's adjusted right...i replaced my tranny and it did the same thing...i then had to adjust the TV cable and it fixed it
Old Nov 28, 2005 | 03:00 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
worn rear end, worn u joint
if there is a noise anyways, clunk or bang
if it doesnt make a noise like that then your idle speed may be up too high
have to remember these cars are lighter in the rear,
they all seem to hit hard into gear
jut how they are, compared to other/heavier vehicles
good luck
Old Nov 28, 2005 | 06:19 PM
Car: 1985 iroc-z
it has been ok since i put new brake pads on the back. i did the master cyl too. since i didnt have much of a reserve. the night i posted this i had done all this. it took a day for it to get better. its like it adjusted itself. either way its all good now....but a new question....
how come these take forever 2 go into gear in cold weather. well..forever is exadgerating...when i put it into drive itll take a second or two for it to do thud into gear..u know like any car does. my old v6 firebird with an extremely healthy tranny in it did the same thing...is it a normal 700r4 thing??
Old Apr 11, 2006 | 08:42 PM
Jforce2409's Avatar
You said replacing the rear brake pads helps your clunking problem? I guess I don't really see how it is related...
hectre13
Dec 11, 2023 08:14 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
