th350, th400, 700r4, t5, t56???
Old Nov 20, 2005 | 02:22 AM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Whats the diffrence in all these transmissions?whats the best/worst ones. wich ones and standard/auto
Old Nov 20, 2005 | 06:17 AM
ede's Avatar
ede
th350 a3 replaced the PG
th400 a3 stronger than th350 seen in taxi/police packages muscle cars 4wd trucks
th700r4 a4 od version of the th400, more or less has soem major weak points and problem spots
t5 m5 seen in about everything
t56 m6 stronger than t5 seen in preformance applications
Old Nov 21, 2005 | 06:31 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
oh, here we go... lol
threads like these can easily turn into a LONG discussion
hey th400 were in 2wd trucks too... lol....
as were the PG, 350, 475, 700r4, and so on
then there were billions of other gm RWD auto trannies from the `60s to current:
including:
3L30 (TH180 / TH180C)
3L80 (TH400)
3L80-HD (TH475) / TH425
3T40 (TH125 / TH125C)
4L30-E (THM R-1)
4L60 (TH700-R4)
4L60-E
4L80-E
4T40-E
4T45-E
4T60 (TH440-T4)
4T60-E
4T65-3
4T80-E
ALUMINUM POWERGLIDE
MK2 / MH5
MX17
SUPER TURBINE 300
TH200 / TH200C
TH200-4R
TH250 / TH250C
TH300
TH325
TH325-4L
TH350 /TH350C
and the manual tranies.,., well good luck, as there were billions of different ones there too,
Old Nov 22, 2005 | 01:23 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
The th350 can be built pretty tough but you have to overdrive
the th400 is very strong by itself and can be made even stronger
the 700r4 is a good dependable trans from 89 and later and you get the overdrive. This can also be built to be beaten on pretty regularly
the BW T5 is an ok manual trans with OD that will literally explode if there is too much torque and traction.
the BW T56 is an excellent trans with the double OD (5th and 6th) but has weak shift forks that will bend or break with heavy use. There are many companies that sell steel (viper) shift forks at a very reasonable price but installing them is a bitch.
the ZF 6-speed which came with the vettes and the vipers is the best of the standards. It can handle 450 ft/lb of torque all day long but it is a hassle to install in anything but a vette.
Of course you also have companies like richmond that sell standards with any range of gear selections and can be built to handle serious horsepower.
Old Nov 22, 2005 | 01:30 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If your looking for a trans you can pull at the junkyard and beat the living **** out of it, your best bet will be TH350 or TH400.
My current TH350C was a junkyard pull about 10 years ago, Believe me it hasnt had an easy life either. The lockup was never wired in so its running fairly high temps but has never gave a single problem.
The TH700R4s are a very weak trans in stock form especially the pre 87s. But they can also be built to handle reasonable ammounts of power.
REVLIMIT
Feb 4, 2003 08:42 AM
mult68
Oct 24, 2001 10:34 AM
Mike86Z28
Sep 24, 2000 10:22 PM
