Making a posi help
Old Nov 22, 2005 | 12:49 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Axle/Gears: 4th gen 3.42 posi
Making a posi help
My current set up is the stock 2.73 non posi on a '89 v8. I can get a posi carrier from an '86 iroc from a local junk yard. Will it bolt right on? Also can I use the ring and pinion from a '91 v6 since it has a higher gear ratio?
Old Nov 22, 2005 | 01:14 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the carrier will bolt in without a problem. I am pretty sure the axles were the same spline throughout the production run. make sure you get the 10 bolt rear though. There are a few 9 bolt units out there and they look exactly the same but are very different.
http://www.chevyhiperformance.com/techarticles/49998/
contact mark@hpsalvage and he can give a pretty good deal on a low mileage rear assembly that will be guaranteed to work.
I am 99% sure that the rear end from a 93-97 camaro will work also. The only concern I have are the splines.
Old Nov 22, 2005 | 01:35 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I think your going to have a big problem here.
In the late 80s (88 up i believe) GM changed from a 26 to 28 spline axles. and you also had 10 and 9 bolt rears in these cars too. none of these parts are interchangable.
You could swap in the entire rear end though, that should be a breeze.
Old Nov 22, 2005 | 04:57 AM
ede's Avatar
ede
regardless of what you might read on here the number of splines on the axle will have zero effect on the ring and pinion set. you can use any ring and pinion set as long as it's for a 7.5/7.62 ten bolt and the carrier series matches the gear set.
Old Nov 22, 2005 | 07:43 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Yes gears will be fine but the posi carrier isnt going to work.
Old Nov 22, 2005 | 11:47 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Hey 1981LT1, thanks for the link, lots of good info.
So the posi carrier from the '86 Iroc might not work because it's designed differently? If anything I can buy all the guts including the pinion yoke. Will that work?
Any other thoughts, let me know.
Old Nov 23, 2005 | 05:15 AM
ede's Avatar
ede
there's about a 10% chance the 89 carrier will have 28 splines. take yuor axle and check it before you buy it, or buy the carrier and the axles too. axle spline count is a simple problem that is easy to over come. don't get hung up on that minor point.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
novaderrik
Aug 10, 2015 12:44 PM
