Driveshaft size???
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Driveshaft size???
How big or strong of a driveshaft do you think I need for some hard street use but mostly normal driving with a T-56 and a 500 peak HP motor. probably somehting like 480 TQ, flywheel.
Thx for any help
Thx for any help
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Inland Empire told me 3.5" Alum with at least 1330 (or better 1350) solid Spicer joints would hold me to 550 hp or so. You have to watch because some driveshaft makers use thinwall tubing that is not as strong.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes its all about the wall thickness
typically larger diameter shafts were thinner walled than smaller diameter shafts
in most all factory installations anyways
good luck
good luck
Pac J
May 17, 2020 10:44 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
