Will/Is my stock TCC locking???
Old Nov 27, 2005 | 08:19 PM
mateo's Avatar
Car: 90' Trans Am
Engine: 94' LT1
Transmission: Built 700R4
Have an LT1 93'pcm and harness to a 700R4 (getting a 500hp built one tommorow to install with a stock TCC)
My question is, I have the VSS connected, car runs awsome...I myself did not do the conversion it was done professionally years ago from the last owner but am I getting lock up??
Im going to check tommorow when the sun is up but my VSS should be connected to the 93'LT1 PCM correct?? or not??
I know its the VSS that controls lock up in the converter but im confused as to whether or not mine is working or not, how would I tell?
Or is VSS supposed to be connected to the original 90's ECM??
And I do plan on keeping a 700R4 at all times with this engine/car combo, no interest in going to the later Electronic version of this tranny.
Old Nov 27, 2005 | 08:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All stock 700R4/4L60/4L60E torque converters have clutches.
Old Nov 27, 2005 | 09:17 PM
mateo's Avatar
Car: 90' Trans Am
Engine: 94' LT1
I understand that, but Im wondering that If the VSS is functioning from the trans to the PCM then lock up should still be occuring....correct?
Old Nov 28, 2005 | 12:58 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The VSS is one of several inputs the PCM uses to decide when to lock and unlock the TCC.
BRoss99
Aug 10, 2025 05:08 PM
I'llrocya
Feb 2, 2016 11:43 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
