In the middle of t-5 swap!
Old Nov 28, 2005 | 11:08 AM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
Yesterday I pulled the t-5 from an '84 Z-28. I'm putting the t-5 in my '85 T/A(LB9). I have the tranny and shifter out. I have some questions though. First, my friend said that my T/A is setup for a clutch even though its auto. Under the dash left of the brake pedal theres this plastic panel. Do I just cut the panel out and is that where my clutch pedal is going to be bolted? If so does this mean I won't have to cut a hole in the firewall for the pedal? Also about the hydralic clutch assembly, are the master cylinder and brake boosters the same on both of these cars? The Z has a white cap for the hydralic clutch on the master cylinder. Do I just take the cap and its hoses over for my T/A? One more for now- what else besides the brale pedal assembly do I need to take from the Z? I need to go ahead and take whatever I need so I can get rid of the Z.
Old Nov 28, 2005 | 01:29 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
First, TA and the TA mount are universal between stick and auto cars.
Second, the underdash panel is probably already marked on the backside for a clutch pedal cutout. Just follow the line and cut it out.
Third, you need to cut a hole in the firewall for the pushrod and drill two holes for the u-bolt. These holes may be pre-punched in the firewall pad already. You can use that as a guide to show you where to cut.
Lastly, master cylinder and boosters are the same between cars. Use the clutch master mounting bracket from the stick car, which will mount the master on one of the studs for the master cylinder.
Old Nov 28, 2005 | 01:55 PM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
So all I need from the stick-car is the clutch pedal assembly and the cap thats on top of the master cylinder?
Old Nov 28, 2005 | 06:15 PM
You need the clutch pedal assembly, clutch hydraulics & mounting hardware, and console plate (though this will be different between a Camaro and a Firebird).
Old Nov 28, 2005 | 08:19 PM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
I plan on getting a 4th gen center console, so is the console just to surround the shifter or is it absolutly needed?
Old Nov 28, 2005 | 08:21 PM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
Also do I need to take the speedo cable or would it be just as easy to but a new one for like $20?
Old Nov 29, 2005 | 12:37 PM
The speedo cable's a pain to remove. Buy a new one, or you may even be able to re-use your exisitng one (unless you've got an electronic speedo now).
Ikes 91Z
Dec 9, 2015 03:49 PM
db057
Sep 4, 2015 07:57 AM
midge54
Sep 2, 2015 06:27 PM
lt1z350
Aug 28, 2015 05:57 AM
Cacike
Aug 27, 2015 05:10 PM
