T5 Swap
Old Nov 30, 2005 | 06:04 PM
BADAZGN's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI TURBO
Transmission: 2004R
T5 Swap
Hello,
I would like to put a 5 speed it the wife's 89 Formula. What year(s) should I look to for the pedal's and assemblies.
Matthew
Old Nov 30, 2005 | 11:18 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
im pretty sure you can use anything from 85-92 camaro or firebird not sure about the other years though. good luck
Old Dec 1, 2005 | 03:54 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
93-97's Also work if you slice off the gas pedal bracket & drill out the top 2 holes on the MC bracket to 1/2". Got a set on mine.
Old Dec 1, 2005 | 04:42 PM
BADAZGN's Avatar
Transmission: 2004R
So are you saying that it is an easy swap for a six speed as well from a 4th gen?
What is involved with that? Thanks
Matthew
Old Dec 2, 2005 | 10:35 PM
n8sz28's Avatar
Car: 85 camaro z28
from what i researched and what other people said a 6 speed is fairly simple except you have to:
1) shorten the driveshaft and rebalance it.
2)get a new cross brace to hold the trans.
3)convert to electronic speedometer depending on the year of the f body.
this is other peoples information though i 'm just reposting it.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
