t56 swap
Old Nov 30, 2005 | 11:20 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
t56 swap
how hard is it to do this swap? LETS SAY YOU HAVE EVERYTHING FROM A 94 CAMARO HOW DO YOU GET IT IN AN 85 CAMARO? what part s do you need to finish the swap? how hard is it to convert cable driven speedo to electo?
Old Dec 1, 2005 | 03:03 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the swap is relatively simple. Spohn sell the crossmember for a direct bolt in. If i remember correctly, you will have to have the driveshaft shortened and rebalanced. The hole for the shifter and clutch hudraulics will be the trickiest part. There are many people who have done this same thing so do a search and see what all the options are. A t56 out of an F-body will have an electric sending unit for the speedo. An aftermarket, and more expensive unit, can be had with either electric or mechanical and still keeps the overall dimension as the T56.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
