5-Speed Shifting Issue
Old Nov 30, 2005 | 10:24 AM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
Ok, This is my first camaro with a manual tranny, and i can't seem to find any relavent info in a search.
http://www.cardomain.com/ride/2113039
I believe it's a T-5 Transmission, and it was running great for about 2 months. Now all of a sudden it's hard as hell to get it into 1st, 2nd, and 3rd. 4rth and 5th don't really give me a problem. I just really really have to force it into first, and 2nd and 3rd are just a pain. and yes, it's got fluid.
Honestly, it feels like the clutch isn't engauging fully. Like If i get it into first, and let off the clutch by about a freaking milimeter, I can allready feel it grabbing. ...That just don't seem right to what it was before. Is there a cable that needs more tension?
I poked my head undernieth, but i couldn't see anything that could be adjusted.. but the exhuast was my main concern at that moment. ...thanks for any help.
Old Nov 30, 2005 | 01:32 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The clutch in your car is hydraulic. Most 3rd gens are, except for the first two years ('82-'83). Nothing is adjustable stock.
Your trans is a T5 Non World Class (1st design).
I would pull the trans and check out the clutch. It isn't that bad a job. The T5 is fairly light. Also, check the rear bearing retainer to see that it isn't worn. The throwout bearing could be getting hung up on a lip on the retainer and not fully releasing the clutch. The retainer is easy to get an costs about $45.
Old Nov 30, 2005 | 01:52 PM
Car: 1986 Vert Z28
Thanks... I'll try and find some diagrams, to visualize what your talking about. but I appreciate the feedback.
Old Dec 1, 2005 | 03:12 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
TKO has some great points to check, but before you pull your trans check your slave cylinder for any leaks / bleed it
jklein337
Sep 19, 2018 06:23 PM
someone972
Aug 30, 2015 12:52 AM
crazynights
Aug 21, 2015 06:53 AM
Bryan F
Aug 18, 2015 02:28 PM
dhonda200
Aug 11, 2015 11:50 PM
