im kinda lost can any one help
Old Dec 6, 2005 | 02:37 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
hey geys i have a question... i have a 91 camaro with a 350 tpi that im converting to a carb and i was just courious if my trans will shift? its the stock 700r4 that came with the 91 camaro so if anyone could help me out that would be great
thanks,
john
Old Dec 6, 2005 | 02:43 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
A 700-r4 is not computer controlled, so yes it should shift fine. Torque converter lockup will not though. You'll also have to rewire the fuel pump relay, as it pulls the power from the ECM and the ground comes from the ECM as well.
Old Dec 6, 2005 | 07:18 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
get a tv cable for a tbi or a factory carb application. the tpi cable is longer and prolly won't allow for proper adjustment.
Old Dec 6, 2005 | 07:24 PM
Engine: 383 SBC
Yeah I forgot to mention that. Check under the tech section there are a few write ups saying exact PNs you need. Also need a kickdown (TV) cable bracket. I bought mine from Summit it's a holley bracket. Also going to need the new studs for the cable hookups. Various other things.
Old Dec 7, 2005 | 09:35 PM
Car: 1982
Transmission: 350
ok thanks guys. Is their anything else ill need besides the engine parts and that?
Old Dec 8, 2005 | 08:44 AM
Engine: 383 SBC
http://5finger.8m.com/tpi2carb/tpi2carb.html
grngryoutmyway
Oct 18, 2016 05:48 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jynx88
Oct 4, 2015 08:19 PM
92projectcamaro
Sep 29, 2015 07:07 PM
3.8TransAM
Sep 27, 2015 08:37 PM
