diagram needed differential with limited slip
Old Dec 12, 2005 | 02:38 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
Ok yesterday the 11th, i replaced the bearing and seal in the rear,,the bearing looked fine but i reaplaced it any way,.hopeing it was my problem some how..but it was not..so any how at least i wont be leaking oil no more...
So so far with this whole project i have determined that, it is not the rear pinion bearings and my rear wheel axel bearings are not my grinding problem.. SO ill be needing to to replace the rear end.
What i want to know is since my problem involves me taking the differential cover off,, can some one show me a diagram of the inside , at what ill be seeing when i open it up,.,.also is it gonna be one of thos deals where ill pull the cover and gear and part will come falling out of it?????.
Old Dec 12, 2005 | 08:17 PM
gottfuel's Avatar
bump
bump
Old Dec 12, 2005 | 08:26 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The picture Lo-tec posted in your other thread will serve good enough as to all the bearing locations.
https://www.thirdgen.org/techbb2/sho...hreadid=335353
Just the guts of the carrier will differ.
Ill see if i can find you a 7.5" diagram...
Old Dec 13, 2005 | 01:07 PM
gottfuel's Avatar
well just by that pick ..iv wont know how to properly remove the axel pin and all that...
Old Dec 14, 2005 | 09:23 PM
gottfuel's Avatar
ok let me try it this way!
could any one tell me what the hardest part of replacing the rear end on my 91 r/s camaro??
Ive done alot of auto matic trans missions but never any, rear ends?? i hear that the trailing arms has a bolt that bonds to the bushings, and the bolt has to be cut, !
MustangBeater20
Oct 29, 2022 09:20 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
