Speedo recal gears, do I need to change both?
Car: 1994 Trans Am
Okay I swapped out the 2.73 for the 3.42's. But I haven't put in the speedo recal gears because getting the 2nd one off the tail shaft looked too tough at the time. And both stock gears are red, which I thought was weird looking. But I could easily swap out the other one. So here's my question, what if I did just that, swap out only the first gear? Would it even fit, would it change anything otherwise?
My bro and I paced one night and if I am going 50mph, my speedo says 57, so that's like 14-17% off. (His tires are shorter than stock)
Car: 1994 Trans Am
What do you mean? I have them but I haven't installed them. I was just wondering what would happen if I swapped out the easy one only.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the gear you have now is the same as the one you're going to put on, you don't need to change it.
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
If the drive gear is still the stock red 17 tooth one and your running 245/50/16's just get a 45 tooth driven gear. That will get you within a mph or two to dead on @ 60mph.
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 7, 2015 04:27 PM
