tv cable adjustment
Old Dec 12, 2005 | 08:55 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
tv cable adjustment
Can someone give me a better step by step process on how to do this...and some better pics. The tech guide isnt all that great (no offense)
Old Dec 12, 2005 | 09:24 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the tried and true way is to set it all the back (towards the firewall) and then connect it back to the carb/throttle body and open the throttle to full. This will adjust the calbe and give you the max setting. You shouldn't go any more than a couple clicks past this though.
Old Dec 13, 2005 | 01:57 PM
Car: 1991 Z28
Engine: SBC
ok heres how i did it...i pushed the button on the kickdown and pushed the place tab that comes out alll the way back into the button assembly like so..heres a before and after illustration..
http://memimage.cardomain.net/member...1_125_full.jpg
then i press the button until the tab came out far enough to reach the wot postition..then i pressed the button again and pushed the tab back again as to wear the pyramid is flush with the button assembly again..
now it shifts really good and has great response when i mash the peddle to the floor..down shifts great
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
