700r4 erratic shifting
Old Dec 21, 2005 | 06:25 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
I just picked up an 85 z28, and of course it has transmission problems. It will not upshift in part throtte until around ~3600 rpm in all gears, and the shift is very hard, tire chirping. If you give it full throtte, it will shift around ~4800 rpm. It also has no kickdown.
I just replaced the TV cable with a new gm unit. Adjusted it as per directions on this site. upshift problem is still the same, and now the trans tries to downshift, but it just shudders. Its weird i have all the gears, but it just wont shift until high rpms.
Anyone have any suggestions? thanks in advance.
Old Dec 21, 2005 | 09:11 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Slipping band?
bad TV cable/wrong geometery?
Old Dec 21, 2005 | 09:34 PM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
With the car running, detach the tv cable at the throttle body and give it a few quick yanks to free what ever might be stuck in the valve or a valve port. Change the fluid and filter or have the trans flushed. It could have a high or failing converter. It could be a failing governor? Just a few things to check. Also what color is the fluid and does it smell burnt?
Old Dec 22, 2005 | 01:08 AM
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Yea, i was thinking that the valve might be gummed up-the car has been sitting for four years. The fluid looks ok, but it does smell a little burnt. Im going to go get a flush and see if that helps out things a bit, ill also see if the governor is sticking or not. Basically im tryin to check everything i can before i take it to a shop, because i know thats probably goin to hurt my wallet.
thejimsterz28
Sep 30, 2015 08:52 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
ironbmt
Sep 27, 2015 06:00 AM
6998poncho
Sep 25, 2015 02:56 PM
